RCU Forums - View Single Post - 2nd plane a 40 or 60?
Old 08-06-2007 | 01:54 AM
bigedmustafa's Avatar
bigedmustafa
Default RE: 2nd plane a 40 or 60?
Nice choice on the Tiger 2/Tiger 60 as a second plane. The only significant challenge that moving up to .60-sized aircraft should present you with is trying to get a larger aircraft packed up into your car.
Larger planes are more stable and easier to see. There is no other difference from an operational standpoint. A lot of pilots stay with .40-sized airframes so they can reuse the engine from their trainer. If you're planning on keeping your Avistar running so you can fly them both, then this is also a non-issue.
Good luck and good shopping.
