RCU Forums - View Single Post - hen long tiger1 modifications
Old 08-06-2007 | 08:32 AM
  #46
JQuest64
Default RE: hen long tiger1 modifications
schutzstaffel, I have a question on the CPU fan you used. I am looking into getting the parts to gether for this mod for two tanks.
What exactly did you use if you remember? Most fans I see are 12V fans that operate between 10 and 12 volts. Is yours in that range and just underpowered at the volt level?
I want to get a fan that works but does not draw too much away from the battery as well. Something that uses low wattage. Any ideas?
