RCU Forums - View Single Post - Ask the pro's.. elevator servos
Old 08-07-2007 | 03:14 PM
da Rock
Default RE: Ask the pro's.. elevator servos
ORIGINAL: CGRetired
Thanks.
What I have is a Seagull Super Star. This plane has an arrangement with one rudder servo and two elevator servo's under the horizontal stab. I opted to make the rudder system as pull-pull which eliminates one servo back there. On the elevator, the holes in the fuselage that were already there, have the servo arms on the same horizontal plane. That makes the choice to have differential or use a Y with a reverser, which is what I did.
The reason I brought this up was that I was somewhat concerned about the potential differential (confirmed by Bruce) that will occur with the up-down setup without a Y Reverser. I was looking to see if the DX7 had some sort of mixing scheme to put the elevator servo's on a separate channel then have them operate that way, but thought that it would be much simpler for the elevators to be connected via the Y Reverser.
And, as I said, in another posting, there is the mention of this up-down setup and I was thinking of the differential posed by such an arrangement.. as of course could be corrected as Da-Rock suggests. But, that means that different cutouts must be made in the fuselage to accomodate such an arrangement.
So, it seems that the simplest design would be to use the Y Reverser.
A third choice, of course, would be to put the servo's in the wing saddle area (there is certainly plenty of room in the Super Star for this) and use either rods or pull-pull. My Excelleron 90 has pull-pull elevators AND rudder. That's a lot of cables going back to the tail.
Dick.
The up/down arrangement works "good enough" for some folks, but usually only when the pushrods are aligned. There will be a very tiny bit of difference, and you'd better pray that you don't need to change what holes the two pushrods are connected to in the servo arms.
The reversing Y will work perfectly as long as the two servos are matched for neutrals and throws. I'd bet the odds are good of finding two that do. But haven't had to do it. soooo
A computer radio will also work perfectly with each servo plugged into it's own recepticle, AND it'll probably let you adjust neutrals, throws etc for each to get very equal outputs. But then......... what if you want to mix rudder>elevator. Radio probably will do it but could take a rocket scientist to set the radio up. That's just conjecture. I never had the radios I've got today back when I used two elevator servos. Back then I had to rewire one servo.
