ORIGINAL: The Real Dogman
Annie is absolutely correct your servos will receive whatever power you send to them via battery voltage
Congratulations Soilworks,,,, I did not see any mention of the Check valve mod, is that working out for you??? I never did hear if you got it tuned well....
The Ofna checkvalve is working out great..I finally have were it's holding a steady idle and not loading up when I come to a stop, and yes I will be adding one to my GST. Thanks again for all your help with the checkvalve, I will be adding one to my TNX which also seems to suffer from fuel pressure issues...Thanks again
