RE: Leopard 2A6 on the prowl
Well the problem was the track catching on the front idler mount then being forced under and bending the pin. This was then shearing the pin through the track itself. I dremeled out the offending area and havent had an issue since.
To keep the linkers on i just hit each one with some CA glue and let it soak in. This tightened up the tolerance fine. I just do an inspection before and after every run and reglue the 3 or 4 linlers/pins that show signs of shifting.
