RCU Forums - View Single Post - Ask the pro's.. elevator servos
Old 08-08-2007 | 06:27 AM
bruce88123
Default RE: Ask the pro's.. elevator servos
ORIGINAL: bigtim
it seems to me there is alot of over complication in this issue by simply fliping one of the servos and using a Y harness while carefully aligning the separate elevators the amount of throw and deflection is negledgable.
not needing either a comp.radio or servo reverser, simply a adjustment in pushrod length for the flipped servo.
the plane will fly fine.
Not true. Flipping (swapping end for end) does NOT change the direction of rotation of the output shaft. It only moves it. He needs to change the rotation direction.
