ORIGINAL: Paul Eagon
The cg is recommended less than 2" behind the firewall with the wheels up
Assuming the firewalls on your Commander is roughly in line with the leading edge of the wing, I think the CG is too much forward. I am comparing with my 1/5-scale Commander where the CG is located 3,5 inches back from the leading edge. That is about 25% MAC. The plane is very stable in the air. Even at slow speed. The huge amount of wash out in the wing helps I guess. ( +3 deg. at wing root, -3,5 deg at wing tip! )
Your Commander is gorgeous! Good luck
