Hi I'v just bought a 3Ch elec heli,.
Its called a : Skyshadow Twin Blade
It seems good, i had to play with the trims for about 10 mins before i could stop it spinning around
Im new the the hobby and wanted something i could destroy by crashing (accidently) that didnt cost much..
Anyhow,
the problem i have is, My heli can hover now, quite hapily, it still turns slightly but only very and it depends on the speed of the rotors.
When i push the right hand stick forward, this should spin the rear roter causing a push of air downward, causing the heli to tilt, and fly forward.
However when the rotor starts to spin, it gets so fast and starts to cause the whole tail to shake, very slightly but it makes a loudish vibrator-type noise and wont spin fast enough to cause the heli to tilt, If i hold onto the bar so it stops vibrating, the rotor spins faster, fast enough to cause the heli to tilt.
How do i stop the tale from vibrateing in the way that it does ??
and sorry for the newbie post :P
