RCU Forums - View Single Post - tdc pinch issues, please help.
Old 08-09-2007 | 03:40 PM
46u's Avatar
46u
Default RE: tdc pinch issues, please help.
ORIGINAL: dustineich
To lessen the pinch atr TDC start engine run extremely rich at full thottle never exceding 140 F for 10 tanks then cool motor at TDC. Repeat process 2 times. If done corectly you should have minal pinch if any. If motor is still not to your liking lean out the motor as much as possible cover cooling head with a sock preferably crew or in a pinch a foam dixie cup will do then procede to hold the throttle wide open until motor reaches desired level of performance.
Hope this helps.
WHAT not me!!!!!!!!!!!!![X(][X(][X(]
