RE: Remove ca/superglue?
Your nail polish remover is basically the same thing as acetone (it has alot of acetone in it) I use straight acetone applied with a q tip and hold the heli vertically to let the acetone do its job. Use the nail polish remover and a hair dryer being careful not to ignite the flammable liquid. It takes a bit of twisting to break it loose......then you can remove it. Other wise you can break off the (ouch!) new tail boom and drill it out, and install a new one.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
