RCU Forums - View Single Post - DPM Ultimate 40 not aligned well!
Old 03-15-2003 | 05:27 AM
WhtBronco's Avatar
WhtBronco
Default DPM Ultimate 40 not aligned well!
I have cheecked both the wing and seat very carefully now. the wing seat is the fault. The good news is by lipping a piece of 1/16" balsa between the wing and the seat it is nearly perfect. I am going to pad the left side wing seat down a strip of 1/16" balsa and patch the covering. I think that will fix the wing. At least it'll be out only about 1mm.
I think I have the tail worked out as well. I actually tried my old trick to untwist the fuse. I took the wings off, sprayed down the inside with water. Then I support the tail of the table with a block under the left side and a weight on the right side. After 14 hours it's nearly dry and it's out about 1.5mm-2mm. I still have to re-shrink the covering though to hold it there. If the tail doesn't hold I think I get some flying wires to pull back to were it should be.
I think I can live with that little bit og alignment flaw. 1/2" on the wing and 1/4" on the tail was too much though. Certainly since they were in opposite directions.
