RCU Forums - View Single Post - DPM Ultimate 40 not aligned well!
Old 03-17-2003 | 04:53 PM
Whirley Bird
Default DPM Ultimate 40 not aligned well!
Originally posted by WhtBronco
Thanks for your suggestion Vegas. It worked perfectly.
. Thank you!
Glad it worked out for you.
You wouldn't want me to build a house for you but I did spend years building wooden canoes and kayaks.
I learned real fast that very hot water allows the strands in the wood pull farther with no fractures.
Drying it bone dry will allow it to take a set.
Remember when your working with thin wood like this you can feel a lot of heat on the other side when using a heat gun but you can still have moisture in the pores of the wood so make sure it's *BONE* DRY*
Have fun flying the plane
