RCU Forums - View Single Post - pinned hinges
Old 08-10-2007 | 11:31 AM
Fastsky's Avatar
Fastsky
Default RE: pinned hinges
I would use the Pacer hinge glue myself. A lot less hassles and it is much easier to use than expoxy. Epoxy doesn't hold that great because there is a slippery film left on nylon hinges that epoxy doesn't stick to that great. Cleaning the hinge isn't required with the Pacer glue, it works as is! It also won't seize up the hinges like expoxy if it gets into the hinge. The stuff is amazing and its all its the only stuff I will use on hinges myself after using it on my last plane. There is no mixing required and that little bottle goes a long way!!! the stuff starts to set faster than you would expect so don't be trying to reposition your hinges after 20 minutes or it might be too late. Found that out!![X(]
