RCU Forums - View Single Post - highlighting problem
Old 08-12-2007 | 09:45 PM
Pushrod02
My Feedback: (16)
Default RE: highlighting problem
ORIGINAL: tippy
ORIGINAL: Pushrod02 ... if you see a problem it's best to have a solution when you keep bringing it up. Lay down the stick bro the horse is dead.
How can it be a dead horse if others keep posting about the problem. Appears this horse is alive and well ...
Want to get truly annoyed with this ... In IE, go to Tools, Options, Advanced ... and uncheck the "Disable Script Debugging" for both IE and Other.
Now see how these great work arounds work.
BTW ... in case anyone is interested ... the debugger errors on LINE 17 on EVERY click in the textbox.
This is where the debugger dies:
...document.selection.createRange().duplicate();
As for providing a solution ... how can I??? The RCU software was working fine several months ago. Now it doesn't. Something on the RCU end is causing the issue and I am not an RCU software tech so it would be literally impossible for me to provide a solution to RCU to fix a problem they created.
I just highlighted your "error message" from the debug tool by click, drag and delete. Upgrade your browser Tippy. IE 7.0 is available from MS and like always, it's free. (hint, here's your solution) I had another issue with some software and low and behold it FIXED the problem with highlighting a quote here on RCU too.
