Mini Ultra Stick
If I get a [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFL2250]Mini Ultra Stick[/link], then what else is required to get it into the air. I know there is a "Needed to Complete" section, but I know that leave small items out. Can someone tell me the things i need (Preferably down to the smallest details. I've never had an electric plane, so i don't know what i need as far as connectors,wires, etc.) .
This is what I have:
[link=http://www.bphobbies.com/view.asp?id=V869660&pid=U867328]charger[/link]
JR 4-channel radio (Still deciding if its worth adjusting trims back and forth, or just to buy a computer radio)
This is my list so far:
Mini Ultra Stick
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLM1400]PARK 450 BL OUTRUNNER MTR,890KV[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKYK5&P=ML]Hitec Micro Pack Micro 05S/3 HS-55 Servos[/link] (I have one, so only 3 needed)
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=PKZ4117]Brushless ESC (20A):3D[/link] (What connectors do I need to make it work with motor and battery?)
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXVJ14&P=7]Master Airscrew 10x7 G/F Nylon Electric Only Propeller[/link]
Servo Extensions & Y-harness (I need something more specific. How many of each? Length of each?)
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLB1025]11.1V 1800mAh 3-Cell LiPo, 16GA[/link]
CA- I have medium. What others do I need?
Now, I need to know like what connector comes on that battery. From the Picture it looks like the red plug that is on my charger, but for the discharge side, what connector is needed? Do the battery and motor have connectors that will work. Is there ANYTHING that i left out?
