RE: Glueing an ABS Cowl
I use CA to tack the pieces together, then use epoxy with fiberglass tape to re-enforce the seams on the inside,then I fill the outside with bondo filler,the type I prefer is"Homefix filler"it sands easy for a smooth paintable surface.
