The MUS is a great plane. You will enjoy it. You really will be better off to get the 480 E-Flite. You will wish you did if you don't. The 450 will fly it fine but the 480 for about $10 more makes it a rocket! You can allways fly at less throttle. You need a better battery. You will pull right about 20+ amps with either motor and a 9x6 prop. The 10x7 is going to be to much for the 450. I would go up to a 25/30 amp ESC also. I would say a 3S 2100 LiPo at 15/20C is about right for the battery. You only need a 6" Y for the ailerons. You will need 3.5 bullet connectors for the ESC and motor hook up. As you see you need to go up about a step on all your parts for the best flying. It really wont cost much more and in the long run you will be very happy with your choice. Good luck, mxerman
