RE: Tamiya King Tiger
Hi,
If your using a standard RC AM or FM radio:
1. Important, remove both DMD units and receiver from the tank's metal hull.
2. Open your KT instructions (at the back) to "Trouble Shooting".
Reinitialize the DMD T-03 Unit to its pre-set condition with the Communications Cable detached from the tested and working MF-01 Unit per the instructions (note: the lights flash after you release the T-03 set button).
3. Up front in the instructions, now go to the the RC unit installation page and program the functions in steps 1 thru 6 (again the units should be outside and away from the metal hull).
Everything should work now.
John
