RCU Forums - View Single Post - Throttle set up
Old 08-15-2007 | 09:31 AM
sscherin's Avatar
sscherin
Default RE: Throttle set up
I used to use cable but I've switched to using .047 music wire in a golden rod inner sleeve (hey if it's good enough for Sullivan Cable it works for me)
I'll solder on a 2-56 threaded coupler and use a nylon clevis on engines with a metal throttle arm. If it's a plastic arm I'll just solder on a metal clevis.
The .047 rod is still fairly flexible but a bit stiffer and lighter than cable. The Servo arm gets a screw set EZ connector..
