RCU Forums - View Single Post - Throttle set up
Old 08-15-2007 | 01:36 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Throttle set up
ORIGINAL: CGRetired
The four stroke, at least the one I had, the throttle was on the other side of the carb (left side if viewing from the rear). That made for some interesting linkage setup in the plane that I had that engine installed. I had to carve some of the fuselage cheek next to where the carb linkage was to make clearance.
On most 4-stroke engines you can turn the carburetor around so that the control arm is in an easier position to route your throttle pushrod to.
Ken
