RCU Forums - View Single Post - idle problems
Old 08-15-2007 | 01:56 PM
zeddfirstwizard
Default RE: idle problems
First off put all needles full clockwise, then turn your high speed out two turns maybe two and A half, then low speed out one turn. Now turn out the idle screw till you get about 1-2mm. Once youve done this make sure that the brake is not messin with the card idle adjustment when you apply brake it should not make the motor change at all. Now start it up. After you get it runnin take it out on A quick run bring it back and check temp. Should be above 200 but below 260. As with all nitro engines she will run better and harder lean. If you got it runnin good and she is at maybe 210 go ahead make small adjustsments to get it up to about 235-240, but keep at least twenty degrees for A safety margin. Dont be tempted to run to lean as it will kill your motor. After you get the right temp and she will idle correctly, Adjust your low speed if nessary to get the bottom end you wan't kep an eye on temp and always always make sure to turn on your receiver before trying to start.... no need to explain. And if you look At google earth your town in cannada has no high elevation problems. The highest point in your town is 1200 ft up and thats not really enough to hurt, maybe minor adjustment but not bad. Enjoy!
