RCU Forums - View Single Post - GST 7.7 Break in blister
Old 08-15-2007 | 08:01 PM
jombo's Avatar
jombo
Default RE: GST 7.7 Break in blister
do this, just like you would run your truck instead of priming first. put the glow igniter on and prime it, it should want to start then pull your finger off the exaust port and try to start it. that is a sure method of it starting. these engines most of the time is a poor prime but if you do it this way you will know when its time to start the motor
