RE: extension instead of switch?
Did that on a jet once after I had BOTH battery switches fail to turn on for a flight. After that, on that plane, I just did what you're doing. I've seen it done elsewhere. Probably more reliable than a switch. If it can flop around a bit, you might want to use one of those plastic keepers on it or tape it every flight.
