RE: CMP giant scale Zero build
I've managed to get some work done on the engine mount. The first pic is of the provided firewall offset to the left .175in to the left, with blind nuts on the engine side. The second picture is the provided engine box slipped over the firewall mounted in picture one. I've added some of the box cutouts back in, three to be exact. then glassed across the box firewall and down the side of the box. The next step is to masking tape over all the blind nut openings that will be inside the box. then epoxy the firewall from pic one into the box, fiberglassing it just like theone on the other end ofthe box. Lastly foam the area between the firewalls.
Joe
