RCU Forums - View Single Post - add on 4 and xp
Thread: add on 4 and xp
Old 03-15-2003 | 05:51 PM
CyberPilot
Default fileread.ini
I have G2 & Add-ons 1 & 4 on XP.
The fileread.ini file is in C:\program files\realflight
If you only see fileread and not fileread.ini it may be because you need to change your view options on your computer.
Open up my computer, click on the 'Tools' menu. Select 'Folder Options' click on the 'View' tab and uncheck the box labeled:
Hide extensions for known file types. Then click OK
That should show you the .ini extension. You can view/edit it with notepad or wordpad.
HTH,
CyberPilot
