RCU Forums - View Single Post - telebee headlock gyro problems..
Old 08-18-2007 | 08:43 PM
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: telebee headlock gyro problems..
Good point tbaus........ that gyro needs to placed vertically and not laid on its back like the ESKY one. I did the exact same thing setting up mine and had to use the helifreak hdx300 set up vid by Finless to find my issue. As soon as I mounted it vertically............ it was rock solid except the slight subtrim adjustments.
With a stock TX, you will have to get it pretty close to begin with and then use the rudder subtrim slider to adjust. The video will show the basics using a futaba Tx but just think of the subtrim menu as your slider on the stock TX. It should work ok until you get the JR set up.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
