RCU Forums - View Single Post - Engine Replacement ... Need advice
Old 08-19-2007 | 12:29 PM
46u's Avatar
46u
Default RE: Engine Replacement ... Need advice
ORIGINAL: jatoracing33
os is the best period...as much power as some big blocks and like all engines if taken care of it will last a long time...its worth the extra money
The OS CV-RX is not like the OS TZ and does not have near the power! I think you have them confused. But is a VERY good engine and has all the power you will ever need and will not tear up the drive train like the TZ will. I know as I have the 18 TZ and not an 18 but the 15CV-RX. Yes it is much better then the 3.0 in my opinion! There are other good engines out there but the CV-RX is very user friendly. Yes if you get the one with the correct shaft will all most drop in. All small blocks are pretty much the same other then the shaft. Now I do not have any idea what they cost in the UK!
