RE: Programming an ESC for Lipos
Willgates351
When you say your throttle is reversed do you mean the direction of rotation or the stick itself. If it is the motor running in reverse swap any of the 2 wires going to the motor. If it is the stick you should be able to just reverse the stick in your handset. I have been using brushless gear for a while and havn't had any problems with the stick as it normally works fine with the hand set not reversed but i have had most motors run in reverse as the coloured wires never match up.
I hope this is some help.
