RE: front diff???
you should tighten that front one, but not as tight as in the back. i would pack silly puddy in it, simply put the more you put in the tighter it will be. you should put just enough in there so that if u spin one wheel, both will not spin in the opposite direction. it should be tight to where it stops quickly and does not spin freely. Also work on your throttle and just learn how to drive your car. each car handles differently and part of it is finding the right way to work with your car so play with it and see what happens.
