RCU Forums - View Single Post - Review: SebArt Katana 30E
Old 08-20-2007 | 05:12 PM
Jake Ruddy's Avatar
Jake Ruddy
My Feedback: (40)
Default RE: Review: SebArt Katana 30E
Now look at your elevator and check your throws and make sure there is no binding of the counterbalances.
Get your hinges aligned properly and use a couple drops of thin CA and glue the hinges in the stab ONLY
Then slide your elevator into the fuse and postion it all the way back allowing the stab to be put into place. For now put the hinges in the stab, do not glue them yet. Then slide in the CF wingtube so that you have a frame of reference to align the stabs. Make sure the stab is perfectly level with the wing tube and use a pit of CA to glue it into place. Lastly use some more thin CA to attach the elevator hinges.
ID:	745858   Click image for larger version
