RE: E-flite Cap 232
I just finished mine up 2 weeks ago. Park 450 motor, electrifly 25A esc, electrifly 910mah 11.1 lipo. I forget the servos I'm using but I had to enlarge the servo openings for them. I THINK they're HS-65s.
I pirated the radio out of my destroyed F-27C Stryker.
It flies great, real light. Getting 7-8 minutes out of the pack. I have a TP 1320 pack I'm going to use, it's even lighter than the 910 Electrifly pack! That should give me around 11-12 minutes.
It doesn't seem to like to glide, gotta fly it in with nose down then flare. I think because of the weight it just doesn't hold it's forward momentum well, and the prop probably acts as a pretty good brake.
I weighed it and I believe I got 540 grams auw. Heavier than the max weight listed on the box.
