RCU Forums - View Single Post - Balancing techniques
Old 08-20-2007 | 10:52 PM
Bad_Daddy's Avatar
Bad_Daddy
Default RE: Balancing techniques
Adding weight to the wings? Don't bother, it won't make a bit of difference to the way any plane flies for you for a long time. IF your skills EVER rise to the level that wing weights matter, by then you will know.
As for weighting the fuselage, get some stick-on weights from your LHS and place then as FAR forward or aft as possible. It takes less weight that way.
