I am not bigboat...but timing alone is not going to give that engine 2000 or 4000 more RPM. You need to do many engine mods to get much higer RPM. By then your engine will not last long. A timing curve is to help the engine run smooth at all RPM. Mostlly at idle and as you go from above idle. Capt,n
