RE: tornado bb trans. (center diff)
yea sounds like youve got the clearance on the gears too tight. you want to have a little play in both gears when the engine is tight. very little play, but still some. hold the clutch bell tight with one hand and look through the bottom of the car and wiggle the trans gears with your other hand. you should be able to slightly move the trans gears without the clutchbell moving.
