RE: E-flite Cap 232
It flies fine on low throttle. It's just if you shut it off that it loses a lot of momentum.
You will have to play with the battery pack position to get the results you want with the CG. If you use the velcro to hold it on, you do have a little bit of room to move it fore and aft.
