You can state the size (diameter and length), weight of the motor and any numbers off of the motor.
What prop size were you running?
Did you take a tach reading?
ESC info?
Battery info?
Answer all of the above question so we can best help you.
http://www.parkzone.com/Products/Def...ProdID=PKZ1267
The 3 hatches, vertical fins, and Elevons and motor mount will cost another $25 roughly.
You might be able to adapt the motor mount to your motor.
Gryphon
