RCU Forums - View Single Post - help with first time OS engine
Old 08-22-2007 | 01:42 PM
dupsta
Default RE: help with first time OS engine
Apollo,
Your instruction guide is helpful, thank you. Gabbonator had posted it earlier in this same thread.
Thanks for taking the time to put it together!
Gabbonator,
Thanks for your patience and simplicity. Using your suggestion I have determined that the flywheel and clutch bell should spin in the same direction. Although rolling the GT2 on the ground, just the clutch bell and spur gear spin , not the fly wheel. I assume the flywheel will need to spin the same direction as the clutchbell.
So with this, my first issue has been solved.
