RCU Forums - View Single Post - Depron Twinkle
Old 08-22-2007 | 04:43 PM
theKM
Default RE: Depron Twinkle
got stuck into some building last night. Bent up some landing gear and laminated the blocks for them to plug into... added them into the fuse with reinforcing triangles to spread the load as well as gluing them to the main spars for strength. Put on the bottom depron sheeting for the fuse, and covered the bottom surface of the fuse and tip floats with .75oz cloth and epoxy resin (this is optional, but the strength and scratch resistance is nice for grass flying). When dry, sanded the excess off the firberglass and finish sanded it a little for a nice and smooth surface. Made up a stabiliser, hinging with scotch tape with a scotch tape reinforced leading edge.
Reckon that one more build session and this puppy is flying!
ID:	747185   Click image for larger version
ID:	747186   Click image for larger version
ID:	747187   Click image for larger version
ID:	747188   Click image for larger version
ID:	747189   Click image for larger version
ID:	747190   Click image for larger version
