RE: what is a glow starter
That's the oil you put in the engine at the end of the day when you are done running the car. You run it out of fuel at the end of the day and put about 4 or 5 drops in the carb and give the pull cord a few pulls to throw it around in the engine. If you don't use after run oil when you are done running then the inside of the engine will rust from sitting with no oil in it.
