what is a glow starter
MI
RE: what is a glow starter
PA
what is a glow starter?
PA
Now I see that you posted about the Xtreme buggy earlier so I guess I know what kind or buggy you plan to order. I am in no way telling you to order from nitrorcx(I have no experience dealing with them) but since your other post mentioned them I would suggest adding this into your order. http://www.nitrorcx.com/starterkit.html
Take a look at some of the other posts here and when you get your buggy be sure to let us know how you like it and if you are having any problems.
TX
Actually your going to need more than just a glow ignitor. You need after run oil, air filter oil, glow plug wrench, 12 batteries and a fuel bottle.
You would be better off buying a kit rather than each piece seperatly.
Racers Edge Starter Kit:
[link=http://allaboutfunhobbies.com/store/catalog/product_info.php/cPath/23_17_29/products_id/216]http://allaboutfunhobbies.com/store/catalog/product_info.php/cPath/23_17_29/products_id/216[/link]
TX
That's the oil you put in the engine at the end of the day when you are done running the car. You run it out of fuel at the end of the day and put about 4 or 5 drops in the carb and give the pull cord a few pulls to throw it around in the engine. If you don't use after run oil when you are done running then the inside of the engine will rust from sitting with no oil in it.
ORIGINAL: danamotocross
if a car has a pull start, do you need a glow starter? what is a glow starter?PLEASE REPLY!!!!!
