RCU Forums - View Single Post - Installing Servos
Old 08-22-2007 | 06:45 PM
aussiesteve's Avatar
aussiesteve
Default RE: Installing Servos
Yep
That's pretty much correct.
When I install them, I do the screw up into the hole but not completely tight - just snug
I then remove the servo and apply a drop of thin CA to each hole and let that fully dry. this hardens up the threads in the hole.
I then install the servo and tighten the screws to the correct tension.
I also use an unserviceable servo (which I have removed the wires from) as my drilling jig. That way I only install the actual servo once.
