RE: throw adjustment
it's a common thing, so i wouldn't worry too much, At first I thought the throw to my trainer was a bit too much.
Then I got a contender...I thought that things was too much at first. lmao
As most people know the contender lacks roll abilities compair to other models.
I get those models like the Sum'in extra..now there's some control surface on models like that
and you can roll to the moon.
I went from too much throw at first to where I can't get enough and extending control surfaces.
It's just a matter of get flight time in. so your brain can catch up. After a while you'll notice
the control surface moving while the model in the air or doing evasive manuvers.
You don't notice stuff like that at first.
You actaully start using your rudder to make minor flight path adjustment without thinking.
Flying becomes natural after a while.
yeap make minor adjustments, in your flying skills and adjusting your models.
Not sure if your instructor just truned you loose, but mine made me do those basic manuvers
again and again at slow speed and just mastering one manuver at a time.
I thought it sucked at first, but in the long run i'm a better flier.
