RE: CMP Hellcat
I now have two Hellcats (CMPro 'copies') awaiting assembly now. Unfortunately I have more planes to fix than I either have to fly or build so, they are on the back burner.
What servos are most of you running, in particular the Hitec models? I'm trying to select a cost effective servo to use and the HS-475s appear to be the way to go. Ideally HS-645MG would be a going in but the local pricing would make them worth more than the plane itself (isn't that always the case).
