RCU Forums - View Single Post - Eclipse 7 600mah Bat.
Old 03-17-2003 | 01:21 PM
Red Scholefield
Banned
My Feedback: (9)
Default Eclipse 7 600mah Bat.
Originally posted by KingOfHearts
Yes I have a Triton to cycle the batteries and I put the discharge to 1.1 per cell but when it did that it brought the pack into the 7v range (according to the info displayed) which ISN'T right...at 1.1 per cell it should be at the lowest 8.8 right? If someone could tell me what settings I should use Yes I have a spectra which gets warm if that makes a difference. It has always been this way...never really holds the charge well...I get maybe 2-3 good 15 min flights out of it before it's at 10.0 to 9.8
What does your Triton show as remaining capacity after your transmitter shows 9.8 to 10.0 volts? Set it to discharge at the same rate as your transmitter, or as close as you can get on the high side. Set discharge cut off at 0.9 to 1.0, 1.1 is too high to get good readings.
