RCU Forums - View Single Post - SPE 40cc
Thread: SPE 40cc
Old 08-24-2007 | 07:38 PM
  #97
RoysterDW's Avatar
RoysterDW
Default RE: SPE 40cc
ORIGINAL: grossy2
Thanks for the heads up Xjet.
Check out these stock # at Tower; GP Velocity Stack LXJ775, HS-625MG LXUZ87, HS-645MG LXUZ89 and you mite want to look at these switch's, EMS Heavy duty DSC switch LXONU3.
Dont forget the Tygon fuel tubing, Gas stopper for tank and neoprene tubing for in the tank (Remains flexable).
Grossy
Hey Grossy
How did you go with the velocity stack? I noticed Eric has on his GP Extra. I bought one as well and had to use the same bolts as the ones supplied by GP are the wrong thread, plus I used different spring washers.
I have noticed the choke doesnt close 100%, maybe 95% due to the velocity stack. I dont think its going to be a problem as the half choke setting is fine and the full choke setting will aslo be fine to prime the engine. I thinks [&:]
Should finish up the tank and plumbing today and going to the LHS to buy an APC 18x10 to run the motor in (with about 4lts of fuel)
Got my elevator servos but still waiting on aileron, rudder and throttle servos.
[8D]
