Originally posted by 3D Joy
What kind of control throws are you using? The only way I got a sorta waterfall is when I use a 14 x 4 on it --> this gives lots of thrust but slow flight.
Anyway, I think you've got something really good. Nice covering ! Makes it LOOK like it's light.
Thanks !!!!!
My control throws really won't help you. I have bigger surface's on the tail. The first flights were with the 14x4. I tried a 13x6 and like it a lot better on this plane.
I just put a Perry pump on it. Tried it out on the ground when i got home tonight. Man, I got the motor running sweet now!! This is my first 4 stroke and was having a little problem getting the motor to run right.
here's a pic of high rate.
