RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 08-25-2007 | 08:11 AM
  #345
CHV69
Default RE: Composite-ARF Integral, kinda build thread
Colin after finishing my second Integral with push rods instead of the stab mounted servos, you may find you will still need to add lead to the nose to achieve the CG you are shooting for. Even after using pushrods I found my battery had to be mounted just above the landing gear to achieve a CG that measures 170 mm
This is with an OS 1.40 RX with ES composite pipe for my power plant.
Carl
