RE: Subtrim? What is it?
Personally, I never use Sub Trim - never saw the need.
As far as Page 5 of the manual, it's a little vague.
What they are telling you is this:
First, set all of your trims to the center.
Then, place the servo arm on the servo so that it is 90° to the servo***
*** what a lot of people don't realize is that with Futaba servos, the servo arms are designed so that whenever you rotate to a different arm you will get a different angle (See illustration)
