Subtrim? What is it?
ORIGINAL: PipeMajor
My 9C has digital trims and subtrims. I can also adjust the digital trim granularity with the trim function just as the 6EXA has. That is not subtrim.
Exactly
AZ
the 9c has sub trim in the main menu. it is like a pre trim if you need it. try to keep it as close to 0 as you can with manual adjustments and servo arm placement.
rob
rob
