RCU Forums - View Single Post - s there a fix for a lose Aileron
Old 03-17-2003 | 06:35 AM
Whirley Bird
Default s there a fix for a lose Aileron
Originally posted by MHawker
Mike
Hi again Mike,
Like I said it's not mine.
I guess i'll see if TH can sell a new wing because it's a lot of work to remove the ailreon,plus replace the hinges.If TH says no then I may drill 1 hole and use the dremel took and drill that rod with a 1/16th bit then sink a screw and blind nut into it since I have all the hardware here.
Thanks for the post
